Fordson transmission help
/ Fordson transmission help #1
Stomper
Saskatchewan, Canada
2017 Kubota L2501
I have a buddy that has reciently bought a Fordson Super Major tractor It's somewhere in the 1964 65 years. According to the info on the net, it has a 6 speed transmission but the transmission shift pattern seems to be only a 3 speed. How are the other 3 gears suposed to work. Any information will be appreciated as there is limited info on the internet.
/ Fordson transmission help #2
Just a guess, but is there another lever to shift between high and low range?
The low and high range is what we thought also but there doesn't seem to be an obvious shift lever anywhere. We are not very familiar with this tractor
/ Fordson transmission help #4
Internet search says it was sold in USA as a ford 5000. Perhaps that will help a forum user provide you info.
/ Fordson transmission help #5
I had a Fordson-Dexta until recently. It had a second shift lever for 'High/Low' range. You might take the shift lever cover plate off (4 bolts) and see if there isn't another shift dog there sans the extra shift lever. There well might have been a reason that the PO took that lever completely out and covered it up.
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
