Fordson major pto shaft
   / Fordson major pto shaft #1
darwinkelsall
63 b414 65 b414 56 300 utility 55 300 utility 55 fordson major 40 miniapolis zts
Any one know if you can permently remove the pto shaft, mounting a backhoe and it's in the way, back hoe won't be coming off, asking before I research to save abit of time
Thanks
Darwin
   / Fordson major pto shaft #3
I suppose you could pull the cove and shaft and fabricate a blank cover.
That is what I want to do, just need to make sure you can just pull the shaft, ie nothing else will fall apart with it not being there and if its just a matter of pulling the shaft or do I have to get right up in it to be able to get it out
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
