sld
Veteran Member
Stirring the pot with ignorance only makes the stew taste bad...
You must be one skinny dude then.............
Dmace said:The Ford F250 4x4 has 2 GVWR packages available (9400/9600) and the LOWEST one (9400) has a payload rating of 2,690 lbs. That should be more than enough for this test. I guess I'm too naive to see this magical GVWR that you see to make a Ford actually handle it's rated payload...
Obviously they left it out because it did better than both. They "conveniently" left it in the drag race since it has the lowest power output but the new HO 800 lb.ft. option will leave them both behind. I've loaded plenty of 1-ton RAM's to know it would easy win the squat test and RAM's have had a fully boxed frame since 2003. Just wait for Rumble in the Rockies II.![]()
