Ford tractor 8 speed manual transmission
   / Ford tractor 8 speed manual transmission #1
hlyautey
Eatonton, GA
1949 8N
My father in law has an old Ford tractor with a 8 forward speed manual transmission. It has a single shifter and the high low range is selected by pressing or pulling the shifter up and down. Does anyone know what model this tractor is? He says it is a 500 but I can't find any info on a tractor of that model.
   / Ford tractor 8 speed manual transmission #2
Haven't heard of that style transmission. I've seen the type with a four speed gear box and then a separate high/low range shift lever.
   / Ford tractor 8 speed manual transmission #3
It is most likely a dual power where there is a direct and under drive for each gear. I think it would also have a high and lo range though? Th e 5000 ford I ran didn't have the fual power but the 9600 did.
   / Ford tractor 8 speed manual transmission #4
Some models of LONG have a similar select shift. I know the one a few places over works that way, I once pulled the cover to fix the shifter when the gal got it jamed up.
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
7046 (A50322)
7046 (A50322)
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2017 Mitsubishi Outlander (A53424)
2017 Mitsubishi...
