Ford/NH 655e wont start/move (electrical?) issue.
   / Ford/NH 655e wont start/move (electrical?) issue. #11
Clean everything off and remove the solenoid coils to see if they have legible numbers on them. Do an internet search or if they are Delta look at their site to get the specs and match them with a coil that just has leads. You can probably call Delta and get some help on a match for the solenoid coils.
On my 4WD coil I found a direct replacement with the wire leads and no plug for under $20. It was part number PDL12. New Holland no longer supplied the coil separate and wanted $500 for a solenoid. Delta had the actual coil with the New Holland plug but it would have cost $120. I found the PDL12 at a dealer somewhere other than Delta direct.
   / Ford/NH 655e wont start/move (electrical?) issue. #12
Well, got the access plate off. Pretty much every wire going anywhere near the transmission is chewed thru or at least stripped back for 3 inches. I think I found my problem. I hope I can guess which ones went to which; because...
was going to see if the connectors were purchasable but just found out *****ing Case/New Holland took down that fantastic parts finder website (partstore.agriculture.newholland.com) they used to have! Now all you can buy is oil filters and pseudorandom irrelevant common parts. I guess they are out of the parts business.
They're in the process of moving to a new system. I had the same problem with getting spray can paint. The link I used just a month earlier was like that. If I recall, your couldn't buy anything from the site yet. I ended up ordering the paint off Ebay and it came from NH. They show about 14.5k products listed.
They go by the name "newhollandrochester" newhollandrochester on eBay
   / Ford/NH 655e wont start/move (electrical?) issue. #13
This is the company I bought the PDL12 solenoid coil from. Their current illustration photo is incorrect so I would contact them the make sure it is the coils with the two leads as it says in the description. The forward and reverse coils have a slightly different appearance but it wouldn't surprise me if the same coil wouldn't work on all 3 solenoids. At $11.50 apiece what do you have to lose?
Search results for: 'pdl12'
Also check your PMs. Click on alerts at the top center of the page and click on your in box.
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT SCL850 STAND ON SKID STEER (A54756)
UNUSED DIGGIT...
