Ford/NH 1920 electric meltdown! Can I use with no electrics?
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #1
Lionhound
Scotland
Ford/New Holland 1920
Like it says, my 1920 had a meltdown. Major short caused total melt of the wiring at the ignition switch and smoke from the starter motor which I am now assuming is knackered. Quickest I can get a starter is 2 days but really need use of tractor urgently. To save having to hire is it possible to use tractor without electrics with a tow start? Would I have to connect ignition switch? If so, how?
Lot of questions for somebody new to this forum but need the help of your wisdom and knowledge.
Thanks in advance.
Rab
Update.
Ok, I removed the relay and put a bridge over 2 of the wires. Tractor started first turn.
All good I thought. Reconnected all electrics, put panels back on, turned key and.................!! well, engine turned and turned but wouldn't start. was like trying to start a tractor with the stopper still pulled out.
Any advice or solutions please?
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #3
Sounds like your fuel solenoid valve is not opening. You should hear it 'click' when you turn on the ignition. If no click, you can apply 12 volts to the solenoid valve terminals with a 'jump box' or equivalent and then try to start. Ford New Holland Tractor Electric Fuel Shutoff - YouTube
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #4
That or you melted a safety cut out switch . You will probably be rewiring a tractor
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
