Ford Front Bucket
/ Ford Front Bucket #1
tomjr
hayes, Va
Ford 1910
How do you bleed the hydraulic line to eliminate air in the line. I have a Ford 770 front end loader and after replacing 2 lines on right, it goes up, but when I lower it, it goes down then goes up again. Also, it will not lift more then about 10 pounds or maintain the lift. Can anybody help?
/ Ford Front Bucket #2
Just cycle the cylinders about 10 times, and the air should purge itself.
Install a hyd gage and check your relief pressure, and reset if necessary.
/ Ford Front Bucket #3
Make sure your hoses are installed correctly....double-check.....if so then you may have trouble with your cylinders internally (blown seal/loose nut ect)
/ Ford Front Bucket
Appreciate the help. Thanks
/ Ford Front Bucket #5
You may wanna remove the hoses and make sure they didn't get crimped too tight or a blockage of sorts
/ Ford Front Bucket #6
my 735 loader book says run for 15 mins moving up and down to bleed..
RoGator RG1100C (A63688)
RoGator RG1100C...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
7002SFL (A61572)
7002SFL (A61572)
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
84in Bucket Skid Steer Attachment (A61572)
84in Bucket Skid...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
