Ford Front Bucket
/ Ford Front Bucket #1
tomjr
hayes, Va
Ford 1910
How do you bleed the hydraulic line to eliminate air in the line. I have a Ford 770 front end loader and after replacing 2 lines on right, it goes up, but when I lower it, it goes down then goes up again. Also, it will not lift more then about 10 pounds or maintain the lift. Can anybody help?
/ Ford Front Bucket #2
Just cycle the cylinders about 10 times, and the air should purge itself.
Install a hyd gage and check your relief pressure, and reset if necessary.
/ Ford Front Bucket #3
Make sure your hoses are installed correctly....double-check.....if so then you may have trouble with your cylinders internally (blown seal/loose nut ect)
/ Ford Front Bucket
Appreciate the help. Thanks
/ Ford Front Bucket #5
You may wanna remove the hoses and make sure they didn't get crimped too tight or a blockage of sorts
/ Ford Front Bucket #6
my 735 loader book says run for 15 mins moving up and down to bleed..
Caterpillar Service Letters from 1980's (A63117)
Caterpillar...
Volvo SD100D Single Drum Vibratory Soil Compactor (A61572)
Volvo SD100D...
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
2024 John Deere TX (A64119)
2024 John Deere TX...
