Ford Front Bucket
   / Ford Front Bucket #1
tomjr
hayes, Va
Ford 1910
How do you bleed the hydraulic line to eliminate air in the line. I have a Ford 770 front end loader and after replacing 2 lines on right, it goes up, but when I lower it, it goes down then goes up again. Also, it will not lift more then about 10 pounds or maintain the lift. Can anybody help?
   / Ford Front Bucket #2
Just cycle the cylinders about 10 times, and the air should purge itself.
Install a hyd gage and check your relief pressure, and reset if necessary.
   / Ford Front Bucket #3
Make sure your hoses are installed correctly....double-check.....if so then you may have trouble with your cylinders internally (blown seal/loose nut ect)
   / Ford Front Bucket
Appreciate the help. Thanks
   / Ford Front Bucket #5
You may wanna remove the hoses and make sure they didn't get crimped too tight or a blockage of sorts
   / Ford Front Bucket #6
my 735 loader book says run for 15 mins moving up and down to bleed..
30008 (A55758)
30008 (A55758)
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
1705 (A54756)
1705 (A54756)
2025 LandHonor LHR-RC9200 Ratchet Binders and G70 Chains (A52378)
2025 LandHonor...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2007 BOMAG BW120AD SMOOTH DBL DRUM ROLLER (A52705)
2007 BOMAG BW120AD...
