ford depth limiter chains?
/ ford depth limiter chains? #11
Hello Soundguy!
I made a set of limiter chains last summer. I've heard them called "check chains" by the old timers here. Anyway, I fabricated mine from some 1/4" chain, some short pieces of flat iron and a couple of very small clevises which hold the chain to the flat irons. The clevises I found at the local farm and ranch store and they were hanging in the store section with all the 3 point links and top link accessories. Since I dont have a welder, I drilled holes in the short ~2" X 2" sections and attached these with the clevises from the tractor top link to the mower's lower 3 pt lift pins.
So bottom line is that I love them! Since I dont have draft control with this old tractor they are a necessity. Actually, I wont even try and mow without them now. If you're interested in my setup, I'll get ya pictures. Id have to dig it out of the snow, tho....Im using them on an old Allis D14 and a really junky BMB 5' rotary mower.
dwight
/ ford depth limiter chains? #12
No luck finding them at 3 different TSC stores. I just ran a chain around the bracket that holds the top link and hooked the ends to the lift arms.... works, but not what I want. Don't have a torch and welder anymore, so need to buy some. Pls. post if you know where they are sold.
/ ford depth limiter chains? #13
Here's what I rigged up. Chains stay on the mower and the height can be changed while sitting on seat. I'm not sure if the weight of the mower should be resting on the top-link bracket. Seems to work good though...
/ ford depth limiter chains? #14
Yeah looks good. I was wondering what is the best place to hook on the mower. Most I've seen were hooked to the lower 3 pt. hitch pins. I just put the chains on the lift arms right behind the rods that pick them up. Plan to try hooking to the mower next. My tractor has a leak in the hydraulics that will be hard to fix so I don't use the lift to hold up the mower while cutting. Long as it's held up by chains I don't see much leaking out.
Still want some of those brackets if anybody knows where to buy. Sold my torch and welder years ago, and trying to get some made at a shop would be a hassle I bet.
Jeff just occurred to me if your chain popped out of the blue hook while mowing it might get in the drive shaft. Not likely, but with these old tractors if something bad can happen it probably will.
you likely would have to buy them online at tsc, vs the store.. however as has been shown.. you can build them too with a lil ingenuity as I did and others.
valu bilt has them.. takes 2 of their kits.. thus probably near 50$ to get a pre made set..
Valu-Bilt 902494
/ ford depth limiter chains? #16
Steven's Tractor Co. in Louisianna sells the Zerco limit chain kit, which has been around since the 50's, probably earlier. TSC once sold the Zerco kit.
Open link:
Chain Limiter Kit
I use different colored zip ties to mark links appropriate to my implements....mostly used with rotary mower.
I use bungee cords to put tension on the chains so that if a chain or fitting should come loose the dangling end will be pulled away from the PTO shaft.
near identical to the valu built one..
/ ford depth limiter chains? #18
I hadn't thought of that. It would have to jump out of both chains at the same time because I attach the loose ends together at the top. I suppose it's possible though. I'll have to connect a safety lanyard or something. Thanks for the heads up...
/ ford depth limiter chains? #19
duplicate
i us a bunji to contoll the loose ends on mine if i even seperat ethem.. many times I union the chain and slip over the rocker..
1604 (A57192)
1604 (A57192)
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
BOX BLADE (A58214)
BOX BLADE (A58214)
