ford deisel
/ ford deisel #1
AUGERDOG
west falls NY
INT -300 utility
1980 ford 1900 what would the compression for this deisel thanks
/ ford deisel #2
Welcome to the forum. Diesel engine compression is pretty high. I am not sure what the range is for your tractor.
/ ford deisel #3
There is not a spec given for actual compression. Compression ratio is given but not a number that can be read on a comptession tester. Check alll 3 cylinders and see if they are all closee to the same. Just make sure that you have a diesel compression tester. You will blow apart one for a gas engine.What kind of problems are you having.
Bill
/ ford deisel #4
Diesel cranking compression is in the 450-550 psi range. You need a special guage for diesels
/ ford deisel #5
:welcome:
2007 WESTERN STAR  4900 TRI AXLE (A65643)
2007 WESTERN STAR...
WOLVERINE TRENCHER ATTACHMENT (A64277)
WOLVERINE TRENCHER...
2022 EZ-GO ELITE...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2008 R&R FLATBED WINCH TRAILER (A65643)
2008 R&R FLATBED...
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
