ford deisel
   / ford deisel #1
AUGERDOG
west falls NY
INT -300 utility
1980 ford 1900 what would the compression for this deisel thanks
   / ford deisel #2
Welcome to the forum. Diesel engine compression is pretty high. I am not sure what the range is for your tractor.
   / ford deisel #3
There is not a spec given for actual compression. Compression ratio is given but not a number that can be read on a comptession tester. Check alll 3 cylinders and see if they are all closee to the same. Just make sure that you have a diesel compression tester. You will blow apart one for a gas engine.What kind of problems are you having.
Bill
   / ford deisel #4
Diesel cranking compression is in the 450-550 psi range. You need a special guage for diesels
   / ford deisel #5
:welcome:
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
International 4700 Vibra Tiller (A51039)
International 4700...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
