ford county pto clutch valve problems.
/ ford county pto clutch valve problems. #1
bobmackay
callander
ford county
when the pto lever is moved no matter what position it is in the pto will not stop turning
/ ford county pto clutch valve problems. #2
what model county is it. it could either have a brake pawl or a brake band no matter which one it has that is most likely what is wrong with it
/ ford county pto clutch valve problems. #4
What model County?
/ ford county pto clutch valve problems. #5
6 Sil non turbo.......I stripped the pack complete and reassemble it .......toke it to the hydraulic people for testing .....clutchplates lock-up at 9.1 bar . I am happy . Test my oilflow from pump and saw a lot of air coming threw . Test pump without the pick-up and filter and then is was without air . I replaced the o-ring at the pump inlet aswell the o-ring at the filter special flange (that one with the grubscrew) and test it again . Now the oil was without air . Reassemble and this County is working now !
