ford backhoe fuel tank cleanout
   / ford backhoe fuel tank cleanout #1
johninrochester
1981 ford 545
I have a 1977 550 , whats the best way to clean the bottom of the fuel tank , without removing it?
Thanks john
No bugs?
   / ford backhoe fuel tank cleanout #4
Depends what's in the bottom of the fuel tank. I rigged a Goldenrod filter to the suction side of a 3/8" gear pump and a hose with a 1/2" copper tube wand that went down through the filler hole into the tank. I plumbed the pump discharge to the fuel tank outlet connection downstream of the shutoff valve. I ran it for 20 minutes, swishing the "vacuum wand" around all corners and the bottom of the tank. Worked great, got lotsa crap out (trapped in the Goldenrod) and the fuel is sparkling clean now. Don't even attempt to try this with a gasoline tank for obvious reasons, and don't be a Darwin candidate and use a drill pump either.
2012 INTERNATIONAL WORKSTAR 7500 HYDROVAC GUZZLER TRK (A53843)
2012 INTERNATIONAL...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
