ford backhoe fuel tank cleanout
   / ford backhoe fuel tank cleanout #1
johninrochester
1981 ford 545
I have a 1977 550 , whats the best way to clean the bottom of the fuel tank , without removing it?
Thanks john
No bugs?
   / ford backhoe fuel tank cleanout #4
Depends what's in the bottom of the fuel tank. I rigged a Goldenrod filter to the suction side of a 3/8" gear pump and a hose with a 1/2" copper tube wand that went down through the filler hole into the tank. I plumbed the pump discharge to the fuel tank outlet connection downstream of the shutoff valve. I ran it for 20 minutes, swishing the "vacuum wand" around all corners and the bottom of the tank. Worked great, got lotsa crap out (trapped in the Goldenrod) and the fuel is sparkling clean now. Don't even attempt to try this with a gasoline tank for obvious reasons, and don't be a Darwin candidate and use a drill pump either.
safety baskets (A53421)
safety baskets...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
LIKE NEW John Deere 10 Lug Sprayer Wheels and Tires (A53473)
LIKE NEW John...
