Ford 9600 70’s - 80’s model won’t start
   / Ford 9600 70’s - 80’s model won’t start #1
Ajcracker
Kioti CK 30
Whe trying to start my tractor, I fed the starting fluid too soon, which caused one loud knock and the engine turned backwards. I again tried to start it and it cranked OK, but would not start. I checked the supply pump and it was delivering fuel. Next I loosened the number one cylinder fuel line at the injector, and there was not any fuel coming out. Then I loosened all six of the injector lines at the pump, and cranked it over again, but still had no fuel coming out.
Is there something that can shear off in this situation, or does it destroy the pump if it is turned backwards? I have been told that this can break a piston but except for the initial knock I haven’t heard anything else that sounds broken.
The man who owns the tractor is 80 years old and doesn’t get on the Internet, so I am posting this for him. Thanks for any advice.
   / Ford 9600 70’s - 80’s model won’t start #2
No, the pump won’t break if turned backwards..
   / Ford 9600 70’s - 80’s model won’t start #3
Loosen the return line on the pump and work the hand primer until fuel comes out and tighten..
Next loosen the lines AT THE INJECTORS and crank the engine until fuel squirts out and tighten..
Now, crank the engine w the throttle wide open and b prepared for it to start..
Good luck
We will give that a try, thank you for your input.
   / Ford 9600 70’s - 80’s model won’t start #5
There’s a video on utube..
Just type Ford 9600 injection pump..in google and it pops right up..
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
Year: 2010 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 81,045 Plate: Body Type: 2 (A51692)
Year: 2010 Make...
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
