Ford 951 Special rotory cutter shear pin
   / Ford 951 Special rotory cutter shear pin #1
carroll ertel
JD5205
I have an old Ford 951 Special rotary cutter . The shear pin has broken off and the pieces are gone , the only thing i can figure out is it must be some kind of bolt with a blank shank with a lock washer and nut to hold it in place . The hole does not appear to be tapered as it would be if it were a traditional pin . If this is right , what hardness and size does the bolt have to be , or do i have to buy it from a parts dealer ?
   / Ford 951 Special rotory cutter shear pin #2
I like to use gr2 bolts as shear pins.. sometimes even if the manual calls for a 5.. more protection.
in any event.. I have a 951 manual at home I'm thinking.. will take a look.
soundguy
Thanks Soundguy. Let me know what the manual says. Carroll
   / Ford 951 Special rotory cutter shear pin #4
per my original 951 manual
48 and 60" 951 use a gr2 1/2" x 3-1/2" capscrew... 72" uses a special sized pin, obtain from dealer...
i'm guessing that just means shape.. i bet it is gr2 as well.
cnh calls that pin on a 72 a AUB150115
i get no google hits on that part number.
me/ i'd stuff whatever gr2 bolt fit in the and figure out how to lock it in.. whether I had to fab something with a headless bolt.. or whatever.. be creative... it just needs shear protection.. and needs to stay in till sheared.. then be able to be easilly removed and repalced... so if you make something.. stick to those rules.. AND make up a handfull of them at the same time.. :)
soundguy
Thank you again soundguy , and i appreciate your time and effort . Will take your advice . Carroll
   / Ford 951 Special rotory cutter shear pin #6
good luck.
soundguy
Hey Soundguy , I went out last night to my local Tractor Supply and picked up four 4" gr. 2 2 5/8 blank shanked bolts and put one in this morning with antiseaze on it , added a lock washer and nut and bush hogged all day . All is well . thanks again . Carroll
   / Ford 951 Special rotory cutter shear pin #8
if it works, it works. glad you got it going.
soundguy
   / Ford 951 Special rotory cutter shear pin #9
I agree with sound guy. I buy bulk/lb grade 2 from TSC (Tractor supply) for Cub Snow Thrower plus my PTO driven PHD (also TSC variety). I have to deal with a very rocky
(field stone) soil for the PHD plus frozen Horse Turds and hidden 2 B stone in the Winter months.
Grade 2's have worked out very well, although much more frustrating with the very frequent breaking during PHD (post hole drilling).
regards,
Steve
2019 John Deere X580 Lawn Mower (A51573)
2019 John Deere...
FAKE (A52472)
FAKE (A52472)
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
LOT NUMBER 251 (A53084)
LOT NUMBER 251...
