Ford 917L 60" Flail Pully
   / Ford 917L 60" Flail Pully #1
Jeepdoc78
John Deere 855
Hello all,
Last year I picked up a Ford 917L flail to use behind my 855 in an effort to keep the pastures around my house in check. I installed all new cutters from Flailmaster and it worked fairly well. The cut was great but the unit had some vibration. Upon inspection I could see the pulley on the cutter shaft moving. Turns out it's not the stock pulley and actually has a tapered bore (shaft is straight). I can grab it and wobble it back and forth.
The pulley is measuring 5 inches across. Can someone with a 917L measure the pulley on their flail so I can try to source the correct size pulley?
Thank you!
Hello Harry,
That is the drawing/pulley I am asking about. The only price I can find for that part is around $290. I am hoping to find out the diameter so I can try to source one that is a bit lower in cost.
Thank you.
   / Ford 917L 60" Flail Pully #4
I see. I hope you have better luck than I'm expecting. I'd say the odds of someone reading your message and actually having a similar machine, built for only a couple years some twenty or so years ago are probably pretty slim. I do however, have a few ideas on some options you might consider if that doesn't come through for you.
   / Ford 917L 60" Flail Pully #5
You might try Shoup for a replacement pulley, they carry a ton of replacement parts and good prices too. I buy from them every year.
   / Ford 917L 60" Flail Pully #6
My 917 has a "K" in the serial number; the pulley is 7.58" OD. The belt tensioner is different from that shown above.
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
1831 (A51247)
1831 (A51247)
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
