Ford 8n
   / Ford 8n #1
phillmo
Wakefield KS
Ford 8n
Trying to find what size/model baler that can be used with an old 8n. Not concerned with manufacturer. Field is fairly flat and I don't plan to pull a trailer.
Thank you for any assistance.
Phillip
   / Ford 8n #3
A welcome to TBN. Have fun and enjoy hours of entertaining and educating reading. :welcome:
   / Ford 8n #5
welcome. I'm guessing a john deere 14T baler might work. You will most likely need an overrunning clutch for the PTO. Hard thing about the 8n is getting the tractor to go slow enough to bale do to the gearing of it. But I know it can be done because I have seen vids on youtube of 8n's baling hay.
   / Ford 8n #7
Welcome to the forums from Oklahoma.
Ken
   / Ford 8n #9
You need an old baler that has its own motor on it.
An 8N doesn't have a live PTO so when/if you stop
to let the baler catch up the baler also stops running.
You need a baler with its own motor so it can run
independently of the tractor's PTO.
Pooh Bear
   / Ford 8n #10
I run an old new holland #67 and it is pretty good. You don't need independent PTO, you just need to learn to rake well. You do however need an over running coupler and probablly a 1 1/8 inch to 1 3/8 inch adapter which can be one unit. Any old baler should be OK, JD 14t, Massey 12, International 45, New holland 65, 66, 67, 68, 69. I like the new holland and the JD has a pretty good following, Although I would find a dealer and see what you can get parts and service for. You will get a lot of negative feedback trying to hay with a ford N series but I am here to tell you it can be done, and it can be fun. Good luck!!!
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
