Ford 8N won't stay running
   / Ford 8N won't stay running #1
Jarrod32
Bronze Member
Nebraska
JD 2038r
It will start, run for a few moments, then cut out.
It will start right back up, but same thing...runs for a few moments then dies.
I have checked through the fuel line, and that seems to be all good...
Any thoughts?
   / Ford 8N won't stay running #2
Sounds like the carb float is sticking. Take a wooden hammer handle or similar and peck lightly on the carb bowl, then try it. My 861 does that sometimes if it has been sitting for a while.
   / Ford 8N won't stay running #3
Any thoughts?
Did you check all three filter screens in the fuel line to ensure there is no blockage?
   / Ford 8N won't stay running #4
My brother called saying my Jubilee was doing the same and it turned out he hadn't fully opened the gas valve.
Yeah, I've forgotten to open the valve at times in the past. That's one of the first places I look...it was good.
   / Ford 8N won't stay running #6
Will it continue to run if the fuel tank cap is loosened?
Possible plugged cap vent? (Insects, corrosion).
2018 John Deere 331G Track Loader (A50490)
2018 John Deere...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2008 CATERPILLAR CB434D DBL DRUM ROLLER (A50458)
2008 CATERPILLAR...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
UNUSED Bubble Aluminum Foil Reflective Insulation (A50860)
UNUSED Bubble...
Birmingham Wood Stove (A48837)
Birmingham Wood...
