Ford 8N won't stay running
   / Ford 8N won't stay running #1
Jarrod32
Nebraska
JD 2038r
It will start, run for a few moments, then cut out.
It will start right back up, but same thing...runs for a few moments then dies.
I have checked through the fuel line, and that seems to be all good...
Any thoughts?
   / Ford 8N won't stay running #2
Sounds like the carb float is sticking. Take a wooden hammer handle or similar and peck lightly on the carb bowl, then try it. My 861 does that sometimes if it has been sitting for a while.
   / Ford 8N won't stay running #3
Any thoughts?
Did you check all three filter screens in the fuel line to ensure there is no blockage?
   / Ford 8N won't stay running #4
My brother called saying my Jubilee was doing the same and it turned out he hadn't fully opened the gas valve.
Yeah, I've forgotten to open the valve at times in the past. That's one of the first places I look...it was good.
   / Ford 8N won't stay running #6
Will it continue to run if the fuel tank cap is loosened?
Possible plugged cap vent? (Insects, corrosion).
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2025 Swict 84in...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
