ford 8n tractor runs great, then sputters and dies....
   / ford 8n tractor runs great, then sputters and dies.... #1
adamsonta
Greenville,tx
1948 ford 8n
MY TRACTOR WOULD RUN ABOUT 2 MINUTES AND THEN DIE. WAIT TEN MINUTES, RUN GREAT FOR TWO MINUTES AND DIE AGAIN. REPLACED COIL, NO HELP. MADE SURE GAS CAP WAS NOT PLUGGED. IT ENDED UP BEING TRASH IN THE FUEL CONTROL, ABOVE THE GLASS SIGHT BOWL. TOOK THE ASSY OUT FROM BOTTOM OF TANK AND JUNK RAN OUT. THEN TOOK OUT NEEDLE VALVE, PLUG, FROM THE FUEL CONTROL ANDTHEN BLEW OUT WITH AIR. NOW IT RUNS GREAT AGAIN.
   / ford 8n tractor runs great, then sputters and dies.... #2
:welcome: to TBN from Ohio
tHANKS MURPH....SO GLAD I FOUND THIS SITE. HOPE TO HAVE YOU ANSWER LOTS OF MY QUESTIONS IN THE FUTURE...HA HA
   / ford 8n tractor runs great, then sputters and dies.... #4
The poster you need is Sound Guy. Post this in the Ford section and he will find it. Say hello for me. Turn off your CAPS.
Thanks once again Murph....Tom in Texas
   / ford 8n tractor runs great, then sputters and dies.... #6
how's she running now?
Got the trash out of the fuel control under the tank...the one that has the glass bowl attached to it. That did the trick. I thought it was the coil..i figured it would sputter constantly if it had
trash. Not run for two minutes and then die ? It makes sense too me now. Given time the fuel would drop in enough to run
   / ford 8n tractor runs great, then sputters and dies.... #8
yup. fuel bowl in carb holds some. gets you going.. then starves. wait a bit and enough trickles in for another go.
to save repalcing 30-40$ parts every time it quits.
at moment of death.. check spark. if it has spark.. look at fuel.
that's a good way to begin all 'won't run' diagnostics...
   / ford 8n tractor runs great, then sputters and dies.... #9
Welcome to TractorByNet!
I moved your thread to the Ford Vintage Tractors forum. :)
Thank you, I'm still getting the hang of this !
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A51572)
1989 Chevrolet...
Electric Concrete Mixer (A51573)
Electric Concrete...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
