ford 8n tractor runs great, then sputters and dies....
   / ford 8n tractor runs great, then sputters and dies.... #1
adamsonta
Greenville,tx
1948 ford 8n
MY TRACTOR WOULD RUN ABOUT 2 MINUTES AND THEN DIE. WAIT TEN MINUTES, RUN GREAT FOR TWO MINUTES AND DIE AGAIN. REPLACED COIL, NO HELP. MADE SURE GAS CAP WAS NOT PLUGGED. IT ENDED UP BEING TRASH IN THE FUEL CONTROL, ABOVE THE GLASS SIGHT BOWL. TOOK THE ASSY OUT FROM BOTTOM OF TANK AND JUNK RAN OUT. THEN TOOK OUT NEEDLE VALVE, PLUG, FROM THE FUEL CONTROL ANDTHEN BLEW OUT WITH AIR. NOW IT RUNS GREAT AGAIN.
   / ford 8n tractor runs great, then sputters and dies.... #2
:welcome: to TBN from Ohio
tHANKS MURPH....SO GLAD I FOUND THIS SITE. HOPE TO HAVE YOU ANSWER LOTS OF MY QUESTIONS IN THE FUTURE...HA HA
   / ford 8n tractor runs great, then sputters and dies.... #4
The poster you need is Sound Guy. Post this in the Ford section and he will find it. Say hello for me. Turn off your CAPS.
Thanks once again Murph....Tom in Texas
   / ford 8n tractor runs great, then sputters and dies.... #6
how's she running now?
Got the trash out of the fuel control under the tank...the one that has the glass bowl attached to it. That did the trick. I thought it was the coil..i figured it would sputter constantly if it had
trash. Not run for two minutes and then die ? It makes sense too me now. Given time the fuel would drop in enough to run
   / ford 8n tractor runs great, then sputters and dies.... #8
yup. fuel bowl in carb holds some. gets you going.. then starves. wait a bit and enough trickles in for another go.
to save repalcing 30-40$ parts every time it quits.
at moment of death.. check spark. if it has spark.. look at fuel.
that's a good way to begin all 'won't run' diagnostics...
   / ford 8n tractor runs great, then sputters and dies.... #9
Welcome to TractorByNet!
I moved your thread to the Ford Vintage Tractors forum. :)
Thank you, I'm still getting the hang of this !
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
