Ford 8N throttle keeps going to idle
   / Ford 8N throttle keeps going to idle #1
USMCGrizz
Muenster,Tx
1948 Ford 8N
This just started when i went back to mowing pasture. I set throttle at about 75% to mow but it keeps kicking it back to idle even if I don't have a load on the mower.
   / Ford 8N throttle keeps going to idle #2
See if there isn't a bolt on the linkage that you can tighten.
   / Ford 8N throttle keeps going to idle #3
It sounds like the friction disc, at the bottom of the hand throttle assy., that keeps the throttle in place is worn/deteriorated, and needs replaced, or adjusted as mentioned. I have made them from heavy gasket material, like 1/8" thick to make new one's, and will last a good while. Replacement disc appear to be made of sheet cork gasket.
Here is a link to an aftermarket disc to give you an idea what it looks like. Throttle Friction Disc
Thanks for the quick response. I will check out that disc immediately!
   / Ford 8N throttle keeps going to idle #5
Yep, adjusting the disc is your fix. Really sucks when they don't work right. :)
   / Ford 8N throttle keeps going to idle #6
Sorry guys.. No disc in an n... ;)
The n has a sector plate and a ball in the throttle arm to ride the plate, and a spring tensioner.
The bell crank is on the later machines
2019 KUBOTA SVL75-2 SKID STEER (A51242)
2019 KUBOTA...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2002 GREAT DANE 102" X 53' T/A VAN TRAILER (A51243)
2002 GREAT DANE...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
