Ford 8N throttle keeps going to idle
   / Ford 8N throttle keeps going to idle #1
USMCGrizz
Muenster,Tx
1948 Ford 8N
This just started when i went back to mowing pasture. I set throttle at about 75% to mow but it keeps kicking it back to idle even if I don't have a load on the mower.
   / Ford 8N throttle keeps going to idle #2
See if there isn't a bolt on the linkage that you can tighten.
   / Ford 8N throttle keeps going to idle #3
It sounds like the friction disc, at the bottom of the hand throttle assy., that keeps the throttle in place is worn/deteriorated, and needs replaced, or adjusted as mentioned. I have made them from heavy gasket material, like 1/8" thick to make new one's, and will last a good while. Replacement disc appear to be made of sheet cork gasket.
Here is a link to an aftermarket disc to give you an idea what it looks like. Throttle Friction Disc
Thanks for the quick response. I will check out that disc immediately!
   / Ford 8N throttle keeps going to idle #5
Yep, adjusting the disc is your fix. Really sucks when they don't work right. :)
   / Ford 8N throttle keeps going to idle #6
Sorry guys.. No disc in an n... ;)
The n has a sector plate and a ball in the throttle arm to ride the plate, and a spring tensioner.
The bell crank is on the later machines
Stump Bucket (A50322)
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
