Ford 8N throttle keeps going to idle
   / Ford 8N throttle keeps going to idle #1
USMCGrizz
Muenster,Tx
1948 Ford 8N
This just started when i went back to mowing pasture. I set throttle at about 75% to mow but it keeps kicking it back to idle even if I don't have a load on the mower.
   / Ford 8N throttle keeps going to idle #2
See if there isn't a bolt on the linkage that you can tighten.
   / Ford 8N throttle keeps going to idle #3
It sounds like the friction disc, at the bottom of the hand throttle assy., that keeps the throttle in place is worn/deteriorated, and needs replaced, or adjusted as mentioned. I have made them from heavy gasket material, like 1/8" thick to make new one's, and will last a good while. Replacement disc appear to be made of sheet cork gasket.
Here is a link to an aftermarket disc to give you an idea what it looks like. Throttle Friction Disc
Thanks for the quick response. I will check out that disc immediately!
   / Ford 8N throttle keeps going to idle #5
Yep, adjusting the disc is your fix. Really sucks when they don't work right. :)
   / Ford 8N throttle keeps going to idle #6
Sorry guys.. No disc in an n... ;)
The n has a sector plate and a ball in the throttle arm to ride the plate, and a spring tensioner.
The bell crank is on the later machines
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
1043 (A50459)
1043 (A50459)
2020 Trailerman Trailer (A50514)
2020 Trailerman...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2004 CATERPILLAR D3G XL CRAWLER DOZER (A51242)
2004 CATERPILLAR...
