Ford 8N rims and tires
   / Ford 8N rims and tires #1
drew miller
50 8n & 37 f-12
Restoring a 50 8N rims and center disc are bad need used parts to replace
   / Ford 8N rims and tires #3
Hello & WELCOME to TBN!
I moved your thread to the Ford Vintage Tractors Forum. :)
   / Ford 8N rims and tires #4
how bad is the center? rarely do i see them so bad that they could not be fixed.. even the hat centers.
the rims on the other hand.. if they are really bad.. then you usually replace with a 6 loop rim. even the hat centers will fit the 6 loop rims.. etc.
if your rim isn't too bad it might be saved.
post pics.
it's amazing what you can do with a torch or angle grinder, welder and a drill.
soundguy
   / Ford 8N rims and tires #5
When I swapped rims and tires from my 9N to the NAA I was unpleasantly surprised to discover that the original rims on the NAA had rusted to the center (under the paint) so bad that when I separated the parts most of the metal on the center flaked away and I was left with centers that had a paper thin edge where the bolts go through.
Replaced them with modern centers which as you know are so heavy they can double as mini-wheel weights. :)
   / Ford 8N rims and tires #6
yep.. GOOD 6 loop centers can be heavy. :)
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2013 JOHN DEERE 8235R LOT IDENTIFIER 191 (A53084)
2013 JOHN DEERE...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
FRONTIER WR3212 LOT IDENTIFIER 54 (A53084)
FRONTIER WR3212...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
