Ford 8N rims and tires
   / Ford 8N rims and tires #1
drew miller
50 8n & 37 f-12
Restoring a 50 8N rims and center disc are bad need used parts to replace
   / Ford 8N rims and tires #3
Hello & WELCOME to TBN!
I moved your thread to the Ford Vintage Tractors Forum. :)
   / Ford 8N rims and tires #4
how bad is the center? rarely do i see them so bad that they could not be fixed.. even the hat centers.
the rims on the other hand.. if they are really bad.. then you usually replace with a 6 loop rim. even the hat centers will fit the 6 loop rims.. etc.
if your rim isn't too bad it might be saved.
post pics.
it's amazing what you can do with a torch or angle grinder, welder and a drill.
soundguy
   / Ford 8N rims and tires #5
When I swapped rims and tires from my 9N to the NAA I was unpleasantly surprised to discover that the original rims on the NAA had rusted to the center (under the paint) so bad that when I separated the parts most of the metal on the center flaked away and I was left with centers that had a paper thin edge where the bolts go through.
Replaced them with modern centers which as you know are so heavy they can double as mini-wheel weights. :)
   / Ford 8N rims and tires #6
yep.. GOOD 6 loop centers can be heavy. :)
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
Electric Concrete Mixer (A51573)
Electric Concrete...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
