Ford 8N distributor
/ Ford 8N distributor #1
mx842
Platinum Member
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
Does anyone have any pointers on changing the points in an old 8N front mount distributor. I haven't looked at it yet all the guy said was that it wouldn't start. Someone had told him it might need points or condenser. I had heard these can be a bear to work on and I would like to get a feal for what I'll be up against. Thanks
/ Ford 8N distributor #2
Remove it and take it indoors to tune. Only two bolts, not too hard to get to, and it has an offset tang so you cannot put it back 180-degrees off like typical distributors. There are instructions in the owner's manual and the I&T FO-4 manual, and look for Rachel on YouTube, who has a good video on these. Timing is done with a straight-edge and there is a jig on eBay that makes this very simple. The front-mount coils are typically more of an issue than points and condensers.
/ Ford 8N distributor #3
You may not need to change the points, only adjust them. Be sure they are opening and closing - an ohmmeter can do this if you're on the bench, a voltmeter can do it with the key on while the unit is on the tractor. Use care if installing points, it's easy to short something out.
/ Ford 8N distributor #4
Ed covered it, the problem is more likely coil than points since the front mounts are very delicate animals and it near on impossible to find good quality replacements if you need one. Just be sure the ballast resistor is good and in place.
With a battery you can test the distributor on the bench before you put it back on the tractor.
Last thought, I recommend you get a service manual. Easy to find and cheap for the good information contained.
