Ford 850 and Dearborn Loader?
   / Ford 850 and Dearborn Loader? #1
texasdan
1955 Ford 850
I have a 1955 850 and I'm wondering in a Dearborn Model 19-8A loader will fit on it without major modifications. Any experience with these things, anyone? Thanks ahead of time.
Dan
   / Ford 850 and Dearborn Loader? #2
it's made for a N series... I'd expect some modifications for the front mount, and the rear mounts. I'm sure a welder and torch would likely make it work.
the original front bracket is the classic 'hanger' bracket which is a bracket attached to the kingpin.. later 00/01 series used a different front bolster that had their own method for attaching loaders.. rear mount points will be the rear axle fender mounts.. so similar setup.. just might have to lengthen the laoder frame..
soundguy
Thanks a lot Soundguy. I thought that might be the case. For the price being asked for the loader, I want it to bolt right up. I appreciate the input.
Dan
   / Ford 850 and Dearborn Loader? #4
not a bolt in replacement. even if you made the front hanger work as is.. the length of the tractor is a few inches different.. so would have to be stretched.
soundguy
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2022 Kubota SVL75-2 (A50120)
2022 Kubota...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Engel 20' Boat (A50121)
Engel 20' Boat...
