Ford 850 and Dearborn Loader?
   / Ford 850 and Dearborn Loader? #1
texasdan
1955 Ford 850
I have a 1955 850 and I'm wondering in a Dearborn Model 19-8A loader will fit on it without major modifications. Any experience with these things, anyone? Thanks ahead of time.
Dan
   / Ford 850 and Dearborn Loader? #2
it's made for a N series... I'd expect some modifications for the front mount, and the rear mounts. I'm sure a welder and torch would likely make it work.
the original front bracket is the classic 'hanger' bracket which is a bracket attached to the kingpin.. later 00/01 series used a different front bolster that had their own method for attaching loaders.. rear mount points will be the rear axle fender mounts.. so similar setup.. just might have to lengthen the laoder frame..
soundguy
Thanks a lot Soundguy. I thought that might be the case. For the price being asked for the loader, I want it to bolt right up. I appreciate the input.
Dan
   / Ford 850 and Dearborn Loader? #4
not a bolt in replacement. even if you made the front hanger work as is.. the length of the tractor is a few inches different.. so would have to be stretched.
soundguy
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
