Ford 841 electronic ignition
   / Ford 841 electronic ignition #1
mayer2323
Want to convert to electronic ignition from points . Have just bought kit . Has anyone done this to a 6 volt positive ground system ? Would like some advice. Thanks
   / Ford 841 electronic ignition #2
Reports I have read from knowledgable folks say that 6 volt electronic ignitions are more problematic than 12 volt setups. Voltage drop while cranking is apparently more of a problem, and instead of weak spark as one would have with breaker points, there simply is no spark at all. Make sure your battery cables, battery, and starter are completely up to snuff. As with all electronic ignitions, be absolutely certain your battery polarity matches the requirements of your kit.
   / Ford 841 electronic ignition #3
where you buy the kit
   / Ford 841 electronic ignition #4
Google is your friend. Pertronix makes the most widely available & popular EI kits. Available throughout the US.
If you are in Goshen, CT, I'm about an hour away and can help.
pineplainstractor.com
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A51572)
1998 Dorsey...
Electric Concrete Mixer (A51573)
Electric Concrete...
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
