Ford 801 Stalling problem
/ Ford 801 Stalling problem #21
Fairly certain the needle is sticking but will just take the carb back apart later and polish everything up and check the float hinges to see if they are sticking. Raining here today so it'll have to wait for a bit,,done soaked as is lol..Hope u guys have a great day!
/ Ford 801 Stalling problem #22
main needle should function somewhere between 1.5 and usually 2 turns at most. I've never had to set one at 3. 3 tells me it's having problems getting fuel thru a dirty carb.. or it's lean and restricted getting fuel.
/ Ford 801 Stalling problem #23
Is that the main down stream you are talking about Sound? on the bottom of the carb..I am still learning what all the parts are called since this is the first tractor i have ever owned... I adjusted that screw at 3 on gthe recommendation of a guy on a site before finding this one.
/ Ford 801 Stalling problem #24
Is that what controls the needle setting?
/ Ford 801 Stalling problem #25
The screw on the bottom adjusts the main jet (which adjusts your fuel/air mixture). It could also be callled a needle.
The needle that we are talking about sticking is the one that the float opens and closes. Its purpose is to maintain a constant level of gas in the float boul from which the main jet is supplied. The float needle is adjusted by slightly bending the tang on the float that raises the needle.
/ Ford 801 Stalling problem #26
Thanks Strum for clarifying, I believe the needle inside that the float controls is whats sticking,,due to work and weather i still havent had a chance to take the carn back apart and check everything out...Hope the weather and work will allow me to this week though...
/ Ford 801 Stalling problem #27
drain gas almost all the way down, then dump in a can of seafoam, drain some fromt eh carb to get it to flow thru.. then let it set a bit.. :)
/ Ford 801 Stalling problem #28
Sound, you guys are the greatest..... :)
/ Ford 801 Stalling problem #29
I was told today to check my float height by taking it off and tunring it upside down, what shoud the approx setting be? I may have bent something when i rebuilt the carb,, any ideas fellas?
/ Ford 801 Stalling problem #30
.25" I use a 1/4" drill bit stem as a gauge...
/ Ford 801 Stalling problem #32
good luck
/ Ford 801 Stalling problem #33
ok,,,we tore down the carb,,made a new gasket and adjusted the float to 1/4",,,,looks like the float setting was the problem,,,thanks again guys!!!
/ Ford 801 Stalling problem #34
glad you got it going.
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
3096 (A63117)
3096 (A63117)
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
