Ford 800 Starter Switch
/ Ford 800 Starter Switch #1
Believer
I have one wire from the push button starter switch to a single post starter solenoid ( solenoid also has the large cables from battery and to starter motor). Is the push button connecting the solenoid coil to ground when pushed? I don't see any way it could be supplying positive 12v.
/ Ford 800 Starter Switch #2
Look again at the solenoid. I don't think it can have just one post. It would need one post for the large cable from the battery and another large cable to the starter. It may have only one small wire for the starter switch. Put a meter on that terminal and see if you get voltage when you press the starter button. You could also disconnect the wire from the starter button and use an ohmmeter to ground to see if it's taking that terminal to ground. Read the schematic or do a bit of troubleshooting, I'm unfamiliar with your tractor.
/ Ford 800 Starter Switch #3
Fords use a solenoid that is internally hot and the starter switch provides the ground to complete the circuit, it is NOT the same solenoid as used on the cars and trucks. There was also a version with 2 small posts used on the later hundred series tractors. But I don't see many of those most just use the solenoid with a single small post
/ Ford 800 Starter Switch #4
What John said. You can use a solenoid from early model ford cars or trucks that had two post. You just have to make a jumper wire from battery feed side to the positive post on top. Then the wire from your push button to ground. Will work the same way.
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
John Deere 1023E (A62177)
John Deere 1023E...
