Ford 800 carb problem
/ Ford 800 carb problem #1
Duane salyer
Madill
Ford 800
Have an 800 series tractor replaced shut off valve and fuel line. Tractor ran fine but valve was leaking, now won't start and fuel is leaking out intake of carb... Not sure if it's flooded. Plenty of compression and fire. Any ideas??
/ Ford 800 carb problem #2
needle and seat
/ Ford 800 carb problem #3
I agree with checking the needle and seat. My naa did that for awhile due to very fine crud in the tank. The fuel fills up the lower bend of the air intake hose. Your plugs might have been fouled by gas as well.
/ Ford 800 carb problem #4
Bad shutoff and needle/seat issues.
Remove plugs, clean with spray carb cleaner or brake cleaner.
Make sure crankcase doesn't have gas in it..
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
Kubota M125X (A60462)
(INOP) 2014 FORD TAURUS (A59823)
(INOP) 2014 FORD...
Countyline 3pt 5' Box Blade (A60462)
Countyline 3pt 5'...
Iranch IRET13 (A60463)
CFG Industrial H12R (A60463)
CFG Industrial...
