Ford 7740 ?
   / Ford 7740 ? #1
Decexcav
Ford 7740 SLE
How do you remove the radio from 7740 ford tractor and can you replace it with a regular Car radio?
   / Ford 7740 ? #2
Not sure how to remove the radio since I don't know your tractor model well enough but usually you remove the trim piece that surrounds the radio and then you might need special key tools to remove the specific brand or just start removing screws that hold the bracket in. As long as the tractor has 12 volt ( which I believe yours does) you can replace with any 12 volt car radio.
Hope this helps!!
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
Cat 277 Skidloader (SALVAGE) (A50774)
Cat 277 Skidloader...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
Vermeer 502 Towable Stump Grinder (A50774)
Vermeer 502...
