Ford 770B Loader issue
/ Ford 770B Loader issue #1
PaulT1966
Wilton, NH
Ford 1510
Gentlemen, I purchased a Ford 1510 (mid-late 80's) in March of last year. Had one bucket cylinder repaired about 2 months later. The other one seemed to be newer by the fresh paint & part number stickers, but no idea it's actual age. This year, my bucket has been dropping on it's own, & the issue is getting progressively worse.
My first thought was the control valve, but I don't see any seals along the shaft to let fluid pass, only at each end to seal the unit.
Could it be that one cylinder had a bad seal and caused the other to start leaking due to the additional stress?
Is there anything I'm missing in troubleshooting?
/ Ford 770B Loader issue #2
It only takes one cylinder leak on an FEL to affect the other one because they are linked hydraulically with a manifold.
/ Ford 770B Loader issue #3
The spools are a precision fit and can wear, causing the cyl fluid to escape.
The cyl seals can be worn allowing fluid to bypass.
There are test for each.
Ack! I didn't even think about that! Thank you Fawken!
Is there a special gauge needed for this? How many PSI are we looking at?
Thank you for your response J_J
/ Ford 770B Loader issue #6
You can test one cyl at a time by removing the hose from the base end. Cap the other hose to the other cyl.
Retract the cyl and see if there is a continuous flow from the base end port.
If the cyl test good, and the lift arms still drop. then the valve spools are leaking internally.
A hyd gauge in the hyd system is always good to have.
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
20ft trailer (A61569)
New/Unused 20ft Metal Farm Driveway Gate (A65583)
New/Unused 20ft...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
