Ford 770 loader questions
/ Ford 770 loader questions #1
gator68
Alabama
Ford 1710, 1986
Hello
I have a 1986 Ford 1710 with a front end loader Ford 770B.
First problem:I noticed when raising or lowering my bucket it is not smooth but jumpy. Could somebody tell me the fix for this?
Second Problem: I was backblading this morning and now my bucket will not tilt foward or back but it still goes up and down.
Did I blow a cylinder seal on the tilt cylinder(s) or something else?
Your responses are appreciated.
Thanks Dave
/ Ford 770 loader questions #2
I am assuming this all just started, so if hydraulic fluid level is fine, the first thing to do before any other steps is unhook any quick disconnects and rehook them to see if this helps.
Thanks MMurphy
I'll try that.
/ Ford 770 loader questions #4
Sounds like an issue in the valve to me ,
mmurphy
Finally got some time to investigate my problem. Found that one of the hydraulic line quick connects disconnected. Put it back on and it is working now.
Thanks for your advice and all others that provided information.
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
