Ford 768 Front-end loader leaking
/ Ford 768 Front-end loader leaking #1
AlohaBob
Captain Cook, HI
Ford 1210
Greetings. New member with first post. Tried the search function and couldn't find an answer. Have a Ford 1210 compact tractor with a 768A front-end loader and a Mott Hammer Knife mower. The loader control valve is leaking pretty good around the quick-connect fittings. Does anyone know what size o-rings these fittings take? Also would love to find the owners manual for the loader. Appreciate any info anybody can share.
Thanks!
Bob
/ Ford 768 Front-end loader leaking #2
Bob, welcome to TBN. I may have an operator's manual. As far as the orings, that depends on whether the couplers are still original, but it is easier to remove one and size it up.
/ Ford 768 Front-end loader leaking #3
MIGHT hit the CNH parts site IF the connectors are OEM.
I believe the connectors are original. Don't know for sure as the tractor came with the property. Let me know if you find a manual. Thanks TractorTech.
Thanks Soundguy, I will check the Case New Holland site out.
/ Ford 768 Front-end loader leaking #6
The quick connector fittings are most likely not NH but made by someone else (Parker, Eaton, etc.) look at them for markings. I have not heard of rebuilding QC as most people just replace them.
/ Ford 768 Front-end loader leaking #7
Bob, they are probably Pioneer 4010-3, 3/8" couplers and will indicate such on them. The oring for that coupler is a Ford/Case/New Holland part # 122057 which is 90 Duro, .737" ID x .103" Thick in oringland. Tisco is 218-OR and 906-10. Even if they aren't Pioneer, but are 3/8" couplers, chances are this oring will work.
Another designation for the same is Aerospace Standard AS-568 dash number for o-rings is -116.
Anyway, if you go to a dealer, you can get the New Holland number or equivalent. If you go to an hydraulic shop and maybe an auto parts store, then the number is the dash number.
I do not have the 768 manual by the way.
HONDA Plate Compactor (A64553)
HONDA Plate...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
Wooden chair (A64557)
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
