Ford 730 fel hydraulic help
   / Ford 730 fel hydraulic help #1
jhamblett
1971 Ford 3400
Ford 730 fel
Isssue: lift arms, and bucket "tilt"work perfectly, bucket curl has no power at all.. it only works if rpms are extremely high and only then it will move but no power, take 10 seconds to get it back to fully curled. I have swapped the bucket lines and it does the same but opposite, won't tilt down but curls fine. Filter has been changed and fluid level is at 8in from top. Spools seem to be traveling fully. I took the whole valve assembly apart and Orings and components appear to be in great shape. I am at my wits end. Please help
Same set up as this, plus the self leveling selector.
Gresen CP Series 3 Spool Directional Control Valve Ford D7NNF893H CP-116-J D84 | eBay
   / Ford 730 fel hydraulic help #2
Check for bad coupler.
I do not have any quick connects and I have also checked all connections. Good thing about swapping the lines is you basically check to see if they are clear
anyone else?
UNUSED LONCIN 90 PLATE COMPACTOR (A51248)
UNUSED LONCIN 90...
2021 JOHN DEERE 8R250 LOT IDENTIFIER 179 (A53084)
2021 JOHN DEERE...
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A51247)
2019 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
