Ford 730 fel hydraulic help
   / Ford 730 fel hydraulic help #1
jhamblett
1971 Ford 3400
Ford 730 fel
Isssue: lift arms, and bucket "tilt"work perfectly, bucket curl has no power at all.. it only works if rpms are extremely high and only then it will move but no power, take 10 seconds to get it back to fully curled. I have swapped the bucket lines and it does the same but opposite, won't tilt down but curls fine. Filter has been changed and fluid level is at 8in from top. Spools seem to be traveling fully. I took the whole valve assembly apart and Orings and components appear to be in great shape. I am at my wits end. Please help
Same set up as this, plus the self leveling selector.
Gresen CP Series 3 Spool Directional Control Valve Ford D7NNF893H CP-116-J D84 | eBay
   / Ford 730 fel hydraulic help #2
Check for bad coupler.
I do not have any quick connects and I have also checked all connections. Good thing about swapping the lines is you basically check to see if they are clear
anyone else?
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2007 Mack Winch Truck (A53117)
2007 Mack Winch...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
JOHN DEERE/UNVERFERTH 1700/330 LOT IDENTIFIER 182 (A53084)
JOHN...
