Ford 730 fel hydraulic help
   / Ford 730 fel hydraulic help #1
jhamblett
1971 Ford 3400
Ford 730 fel
Isssue: lift arms, and bucket "tilt"work perfectly, bucket curl has no power at all.. it only works if rpms are extremely high and only then it will move but no power, take 10 seconds to get it back to fully curled. I have swapped the bucket lines and it does the same but opposite, won't tilt down but curls fine. Filter has been changed and fluid level is at 8in from top. Spools seem to be traveling fully. I took the whole valve assembly apart and Orings and components appear to be in great shape. I am at my wits end. Please help
Same set up as this, plus the self leveling selector.
Gresen CP Series 3 Spool Directional Control Valve Ford D7NNF893H CP-116-J D84 | eBay
   / Ford 730 fel hydraulic help #2
Check for bad coupler.
I do not have any quick connects and I have also checked all connections. Good thing about swapping the lines is you basically check to see if they are clear
anyone else?
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53472)
Kuhns AE10 Small...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
