Grading Ford 702A Blade
/ Ford 702A Blade #1
Eric_Whitney
Columbus Ohio
Ford 1210
Just bought a Ford 1210 with 60" deck. While I was picking it up I saw a Ford 702A front blade on the used lot. Does anyone know if it will fit the 1210. Looks like all the mounting hardware is there. How does the hydraulics work if I have no remotes, can you run something with the PTO?
/ Ford 702A Blade #2
How wide is the 702? I expect you dealer can tell you if the mounting hardware will fit. if not it's probably pretty easy to modify to fit. If I remember the 702 right doesn't it have two long arms that mownt to a bracket towards the middle/rear of the tractor. I think you'll find that it will be easier to add remote hydralics rather than deal with a PTO pump, tank and valve. I might be more inclined to use one of the self contained electric units that looks like a hydraulic cylinder. Then all that is required is a switch and a couple of wires
Andy
/ Ford 702A Blade
Who makes the electric units? And that sounds like the 702 Blade, it does have the arms that would come about half way back.
/ Ford 702A Blade #4
I'm not sure where to get the electric cylinders. The ones I have are the dump cylinders for the Cub Cadet Big Country. They were purchased seperately as a option so I suppose that is one way to get them. When I'm down at my farm again I'll look at one and see it I can get a brand name.
Andy
/ Ford 702A Blade #5
I still haven't had a chance to find out the name on the Cub cadet cylinder. I did come across a self contained "Linear Hydraulic Actuator" from KYB that might be of interest, not just here but for anyone who needs another degree of hydraulic contron and doesn't have enough hydraulic circuits. It's from KYB America LLC in Addison, IL 630-620-5555 hyd@kyb.com http://www.kyb.com/power/hymm.htm
Andy
/ Ford 702A Blade
Thanks for the info Andy. Looks like I can run 1 remote off my tractor so this would be good for the blade up and down. Then I could run the angle with the tractor remote.
/ Ford 702A Blade #7
Hi I saw your question about a blade for a 1210 ford. I am looking for some info on one. How it works on the 1210 with no power steering? How does it hook up to the tractor? I need it to move stone. Is it worth putting on?I tried talking to the dealer put no luck there . I would really appreciated your time and input.
Steve
/ Ford 702A Blade #8
Are you looking for info on a loader for a 1210?
I have a Westendorf TA-55 on mine.
/ Ford 702A Blade #9
Hi Sld, I would love a loader for my 1210 but when I talk to dealer they tell me if I do not have power steering it would to hard to steer with a bucket. Is that true? I would appreciate your input and time. Thank you
Steve
/ Ford 702A Blade #10
It is definitely harder to steer but I haven't found it to be a problem. I did replace all the steering rubber and added fresh grease to make sure it was up to snuff. I would not let this stop you.
When you are rolling it is fairly easy to steer. Sitting still and with a full load in the bucket it is hard to steer. I have been moving dirt on top of a dike around a pond. If I need to make a tight turn I set the bucket down enough to raise the front wheels off the ground and crank them lock to lock. Raise the bucket and drive away. It works pretty good and you can do a sharp 3 point turn.
I took the loader off for winter snow removal and maintenance or I would snap some pictures. If you have any other questions let me know.
BTW, I bought my loader on eBay for 1600.00 complete with hoses, valves and brackets, even nuts and bolts. It was an easy 2 hour job to install.
/ Ford 702A Blade #11
Thanks for the info. Do you have to do any welding on the tractor or does it just bolt on. What do you use snow removal?
/ Ford 702A Blade #12
No welding was required. There are 2 brackets that bolt on just behind the front bumper. These are half moon shaped that face forward. The loader bar or pipe fits in here and gets pinned. On the bell housing casting, there are 4 tapped holes on each side. There are brackets bolted here as well, one of which accepts the valve for the joy stick.
It is a really easy installation once you have all the brackets and hardware. Mine is a Westendorf TA-55 and the mount kit came from them but I am using a Ford valve and joy stick.
Keep an eye on eBay and Craigslist. They are not common but the problem with buying new is that the loader cost almost as much as the tractor is worth.
Where are you located?
For the little snow we get here I just use the rear blade. It is easier to store my tractor in the heated garage without the loader on it.
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
Caterpillar D8R/D9R Service Manuals (A63117)
Caterpillar...
(3) 5 LUG TRAILER DROP AXLES (A64280)
(3) 5 LUG TRAILER...
2025 60in Bucket Skid Steer Attachment (A61572)
2025 60in Bucket...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
2018 Club Car Carryall 1700 4x4 Diesel Utility Cart (A61572)
2018 Club Car...
