Ford 7.3L Gas Engine
   / Ford 7.3L Gas Engine #71
They are better at producing torque and more reliable. Seems like a win-win for truck owners
Do not forget push rod engines are more compact. Translates to more room in the engine bay or more room for additional displacement, accessories, etc.
   / Ford 7.3L Gas Engine #72
I'd be curious to know how pushrods contribute torque.
Reliability? Depends on what other parts you include in the picture. I'd be inclined to say it's a draw.
Pushrod engines typically have two valves and big valves with large ports move lots of air which = torque
Fewer parts will always be more reliable. Simple is better at lasting longer
   / Ford 7.3L Gas Engine #74
From the car and driver article... what is Fords logic in doing this?
A slightly less powerful version of the new 7.3, rated at 350 horsepower at 3900 rpm and 468 lb-ft of torque at 3900 rpm, will be standard on the F-450 chassis cab, the F-550, the new F-600, F-650 and F-750 Medium Duty trucks, and F-53 and F-59 stripped-chassis models.
   / Ford 7.3L Gas Engine #75
Derated for continuous (heavy) duty rating.
   / Ford 7.3L Gas Engine #76
Woah I was late to this thread. Was not expecting a full 8 pages already. I will be interested in the tow/haul numbers!
   / Ford 7.3L Gas Engine #77
It’s probably the same engine and tune, in the gasoline engines. For example, the same was done with the 6.2L. All that was done was measuring at different RPM’s (commercial vehicles are rated based on where the sound reaches a certain level), instead of peak power and torque.
The diesel chassis cabs are de-rated, but also use a different turbo and some other parts.
   / Ford 7.3L Gas Engine #78
Go look at the day I graph, from the first page. At 3,900 RPM, it’s the exact same in the regular engine as the commercial numbers. They just don’t list maximum/peak, on chassis cabs.
   / Ford 7.3L Gas Engine #79
It's not a Ford thing. All the big 3 do it for CnC rigs vs pickups. Consensus I've seen is for increased durability. Really the same reason teactor engines are underpowered for their size. Lasts longer & will easily go all day for years on end when you cant push the engine hard compared to a more tuned engine. Most automotive engines would blow up or melt down if pushed hard for significant durations. Fine for short demands like merging. Less fine for commercial duty stuff flogging it all day.
   / Ford 7.3L Gas Engine #80
Got it. Kinda like my old Mercedes 240D. 67 HP was not enough to stress anything out. :thumbsup:
Or get up to the highway speed limit. :shocked:
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
