Ford 7.3L Gas Engine
   / Ford 7.3L Gas Engine #61
What’s wrong with pushrods? I’ve seen more problems with the Ford extra long timing chains stretching than pushrod problems.
   / Ford 7.3L Gas Engine #62
What's wrong with timing belts? Belts nowadays last forever and a no interference engine can be designed to make them an even better alternative.
Ask the V10 owners above how many timing chains they had to replace in 400,000 miles? Find me a pushrod engine that has run that long.
   / Ford 7.3L Gas Engine #63
The only v10 owner I know personally had the replace the chains around 200k. Who cares about 400k? 97 out of 100 light duty trucks are in the junkyard before then. If you’re buying a medium duty truck with the intention of going 400k you probably should get a diesel. And most diesels have pushrods. Go look at the 400k pickup market. The vast majority of them are diesel duallys and the vast majority of those are Chevys from what I see.
   / Ford 7.3L Gas Engine #64
With the V10's I've personally owned, plus other V10's I've known thru friends/family... I've never seen a spark plug thrown. I have seen one of the 2 piece plugs seize in the cylinder after 100k when trying to replace it. That didn't have anything to do with the engine, it was because of the spark club design itself.
Never had to replace a timing chain either.
DID have to replace exhaust manifold gaskets tho...
   / Ford 7.3L Gas Engine #65
Ford should embrace a simplified overhead cam design that eliminates rocker arms. Just because GM can't get out of the pushrod era doesn't mean Ford should go backwards.
OR you could say, ford has come back to the KISS method, in another words, back to what is reliable and works!!
What is probably the most reliable engine ever put in a pu?? I would say Cummins 12valve, and guess what? It has pushrods!
SR
   / Ford 7.3L Gas Engine #66
The long chain issue is not just with Ford...it is a design issue that other makers have had too. A short chain in a pushrod engine can get quite loose but it is controllable, while the same wear with a 4' long chain is a disaster.
   / Ford 7.3L Gas Engine #67
SR
Minus the killer dowel pin issue they are tough.
   / Ford 7.3L Gas Engine #68
Often, before you have a mechanical disaster, a long-chain modern engine will have it's valve timing off enough to throw a fault-code. May still drive fine, but won't pass emissions...... if that matters where the truck is plated.
Rgds, D.
   / Ford 7.3L Gas Engine #69
Your attached picture shows no rocker arms, but some OHC engines have rocker arms. Then you have to include bearing retaining caps and all the associated hardware to drive the cam(s) plus oiling. Overall, it's not necessarily a simpler design.
Why are pushrods not a good design? I know they are archaic, but they work. Am I missing something?
   / Ford 7.3L Gas Engine #70
They are better at producing torque and more reliable. Seems like a win-win for truck owners
2019 CATERPILLAR 289D SKID STEER (A52709)
2019 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
40006 (A55788)
40006 (A55788)
BEFCO 10 WHEEL V-RAKE (A52708)
BEFCO 10 WHEEL...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
