Ford 6640 SLE Engine making Popping Sound out of Exhaust
   / Ford 6640 SLE Engine making Popping Sound out of Exhaust #1
lazy b farms
white deer texas
6640 see
Hoping someone can help me out here. I have a 1994 Ford 6640 that will idle fine but when I give it throttle it will start missing and making a popping noise from the exhaust. Smokes quite a lot too. White smoke and Black. So far I have had all the injectors tested and all were fine. Changed fuel filter and bled the system 3 times. Adjusted all the Valves and they did need adjustment and thought my problem was solved but it made no difference. What is strange when I accelerate the engine runs fine but when it levels out it starts missing and popping again. I would greatly appreciate any help here. This problem came on slowly and would just do this when first started and would clear up. Now it does it all the time. Thanks in Advance.
   / Ford 6640 SLE Engine making Popping Sound out of Exhaust #2
Check the compression. White smoke is unburned fuel. Possibly low compression due to a valve that's not seating correctly or is burned.
   / Ford 6640 SLE Engine making Popping Sound out of Exhaust #3
Timing might have slipped. Or the injection pump might be getting weak.
Injection pump was the problem. $1600 for a rebuild but it runs great now..Thanks for the help.
   / Ford 6640 SLE Engine making Popping Sound out of Exhaust #5
That's good you're back running. How many hp is that ford?
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
More info coming soon! (A50323)
More info coming...
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
SLEF CONTAINED KITCHEN (A52576)
SLEF CONTAINED...
