Ford 6610 Re-sleeving
   / Ford 6610 Re-sleeving #1
jacain
Richmond (Chesterfield), VA
Ford 2600 Ford 3910
Looking at purchasing a 6610 that needs #4 re-sleeved due to hole. Trying to get a quote from my buddy now who owns a machine shop. Owner says it has dual power, but not sure what else. Was wondering if anyone could decode the tag for me. Also, what would your opinion be on re-sleeving? Wants $4000. Full rebuild kit looks to be around $450. Pretty sure these are dry sleeve blocks too. Screenshot_20200610-101435.jpegreceived_252906352809054.jpegIMG_20200610_093919.jpeg
"So I talked to Dad about it, and he said he can offer to do one, but not all 4.... That's a beast of a block!! Lol about $250.00 to clean, sleave, and prep...."
Lol!
   / Ford 6610 Re-sleeving #3
Sleeving one hole is short sighted and foolish. If that is all that will be done, do not even bother.z
I was thinking the same thing. I'm sure the others aren't too far behind it. Thanks for the reinforcement. Still seems like it might be a good deal. I just wish it had the two speed PTO, but it will still make a good tractor for running a round bailer and batwing mower.
   / Ford 6610 Re-sleeving #5
Agree. Move on to another tractor.
   / Ford 6610 Re-sleeving #6
It very possibly is a good deal IF you can tear the engine down and build it back yourself. AND if you can resist half-azzing the block.
Got quote to re-sleeve all cylinders at $1000 for labor (includes cleaning and magniflux). Found some complete rebuild kits to include sleeves for $450. Figured I can get my buddy who owns the machine shop to help me with assembly.
More pics. Looks to have close to 8000 hours on it. I was actually off a little on the machining costs to re-sleeve. Should be more than $200 cheaper.received_1160192617667632.jpegreceived_262533648151369.jpegreceived_261892221545565.jpegreceived_566394364066712.jpeg
   / Ford 6610 Re-sleeving #9
Turboed engine? Not original to the tractor. Be sure to order the correct kit. I would let the machine shop order the service sleeves. Let them and their supplier worry about getting the correct sleeves and installing them right.
I'm not seeing a turbo and pretty sure the 6610 II didn't have one. 7610 had one for sure. Good idea to have them order.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sedan (A59231)
Sedan (A59231)
Millcreek 5ft 3 Point Aerator (A59225)
Millcreek 5ft 3...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
GM 4030-C 6 Cylinder Power Unit (A57149)
GM 4030-C 6...
