Ford 6600 3pt lift problem
/ Ford 6600 3pt lift problem #1
triniman
Trinidad W.I.
ford 6600
Hi, my 3pt is lowering accurately, holding forever, but it only raises when I play with the lift lever or the speed adjuster. My oil has no signs of water and is at a good level, and I changed the filter. What could be the broblem?
/ Ford 6600 3pt lift problem #2
Install a hyd gage and check some pressures.
Thanks JJ, I'm going out to get one now. What max. psi gauge should I use?
/ Ford 6600 3pt lift problem #4
3000 psi.
I'm getting 55 psi every time I raise the lift. The psi reading is constant but the 3ph is comming up in about 3 to 5 short movements.
/ Ford 6600 3pt lift problem #6
No, 55 is not going to be the right psi? Typically around 2000 - 2200 psi, so you're not in the right ballpark.
Sounds like an airleak somewhere or plugged filter, oil is not getting to your pump evenly/freely for some reason.
--->Paul
/ Ford 6600 3pt lift problem #7
It depends on where you have the guage. 55psi would probaly be about what I would expect it to take to raise the lift with nothing attached. The 2000psi should be max system pressure, but you will never find that much in the rockshaft piston unless the lift is connected to something it cannot lift.
Going to search for leaks, plugs and kinks.
/ Ford 6600 3pt lift problem #9
Got it - I guess I'd hook it up to something it couldn't lift, wasn't thinking of just raising empty arms. 55 makes sense then.
--->Paul
/ Ford 6600 3pt lift problem #10
I just have very little experience with fords so I dunno where a system pressure test port would be located.
/ Ford 6600 3pt lift problem #11
Does your tractor have a loader valve or remote vale?
If it does, use a tee and connect it to the IN port of either valve.
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
DELTA UNI SAW (A62131)
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
RoGator RG1300C (A63118)
RoGator RG1300C...
