ford 655c shutdown while running
   / ford 655c shutdown while running #1
cdicksen
Washington, NJ
1990 ford 655 c
I posted this once before but still cant find the problem. My 655c shuts off intermittently like someone shut the key off. When I go to restart there is no power to the key (verified with a test light and by the batt light/buzzer being off)But if you turn the hazard lights and directional signal on the battery light comes on along with the buzzer (but the machine won't turn over). I shut everything down and eventually power is restored to the key, the machine starts and it runs fine. I checked the wires and don't see anything loose but I am going to check the main engine harness connectors under the floor for corrosion but since the problem is intermittent, I really don't think its the problem. I also changed the start relay in the cab but I can pull that one out completely while running and the machine doesn't shut off. Anyone else have a similar problem or what about the fuel shut off selenoid on the injection pump? If that was going bad, would I loose power to the key?
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
