ford 6000 troubles
/ ford 6000 troubles #1
jgrieve
my dad has a 6000 uses it for blowing snow and mowing grass. it has a bad leaking front trans seal it still works ok would it be worthwile to replace the seal? im sure some damage has been done to the selct o speed. the brakes and 3 point arent working, the power steering is. I think they all run off the hyd pump on front? is there a place online where I can see a hyd schematic? any advice would be appreciated. how hard is it to fix a select o speed?
/ ford 6000 troubles #2
I guess this is the 6000 Commander? You might get more responses if you repost here in the vintage section. Another site is ytmag.com. If the select-o-speed is damaged it could be expensive to repair and hard to find parts for. Good luck.
/ ford 6000 troubles #3
Hit the new holland web site.. you can then search for parts and get exploded diagrams.
a MANUAL would be a big help
So far sounds like you go a good engine.. and everything from there back is iffy... gotta love the SOS.. and unfortunately.. for that tractor.. sos was the only trans option... not like you can swap an 8spd into it like you could do with a 5000.. etc.
soundguy
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
Sellick S80 (A60462)
